Steve Kahn
Those rods don't look long enough for a matte box and follow focus.
Will 40cm rods be the sweet spot for most applications?
Just another company to look at... FOR $199
I've used several types of Rods/support rigs but if you're on a budget and need something with good cost-to-value, I've found these to be excellent (for HDSLR and prosumer video cams). And Sean at sales said these are what's recommended for the AF100.
http://www.bhphotovideo.com/c/produ...RS_15IIMQR_RS_15IIMQR_Rod_Support_System.html
http://www.cavision.com/rods/RS15IIMQR.htm
I just received my set of these Cavision rails. As I do not need any support for my Nikon F lenses, I'll simply remove the lens support bracket.
And, when you talk about price/quality ratio, my Cavision follow focus unit (their part no. RFD15S) is way up there: inexpensive, sturdily made, smooth in operation.
Same here, I removed the lens support bracket...
AND there's definitely enough room for my advanced mini FF (the RFD15SM) and my Genus Matte box with Nun's nickers on this support system.
Not sure what to say in response to the other comments above, but this rod/support rig works great!
Also use these QUICK SNAP gears--and use Cine pitch (0.8). Save LOTS of time.
Pharpsied, what is the best solution? I still have no idea which ones to buy.
This is what I have, the Zacuto Universal Baseplate. It is great, I have used this with everything from a DVX to a 7d to a HD110 and even a Krasnagorsk-3 16mm camera. It is a top quality piece of kit and will last a lifetime.
CPM Film Tools makes excellent products. Never scratched, never bent, very, very sturdy, not too heavy.
This still doesn't answer what to use for the lens support. What would people recommend for this?
