AF100 workflow on AVID?
dhart1949
Anyone using AVCHD codec on a AVID. Can you describe your post-production workflow including trans-code if necessary? Thanks.
Same here - make sure you import overnight before your edit, and you'll need a lot of hard drive space as the files are 3 or 4 times larger than your source AVCHD. Smooth as butter once it's in there though :)
Will the Sound Devices PIX 240 make this step unnecessary?
(i.e. Will it be a simple matter of "Plug in the drive, open the file and edit"?)
That would be sweet.
