Glenn Przyborski
I've read a whole lot of comments whereby AF100 users are touting various combinations of gamma, matrix, knee and other settings to achieve the ideal "film-like" image. Panasonic gives you an interesting selection of image controls.
I've worked in high-end broadcast production for most of my adult life and here's my 2 cents worth and how I setup my cameras…
If you're shooting with an AF100, chances are that the footage you shoot is going to be edited by either you or someone else. After editing, someone will probably do some form of color correction (excuse me… "grading") to your project before it's released.
I've learned a long time ago that it's best to start the post-production process with images that are well-exposed, in-focus, with good overall color balance, and absolutely no black clipping or unusual gamma induced contrast. Remember, on the AF100, you only have 256 steps from black to white. Give yourself as much latitude as possible for final "grading" during post-production. I always add the film-like "S-gamma curves" and crushed blacks in post, not in camera.
If you set your camera to crush or deepen low-lights or shadows within a scene, your will see noise and compression artifacts as soon as you try to recover low-light details in post. Also, IMHO the chroma and luminescent channels of the AF100 don't precisely track each other as they approach white clip, which for some reason, Panasonic uses 110 units of video instead of the usual 100 to 103 units.
For what it's worth, here's the settings I use on my AF100…
180 degree shutter
Scene Select F1
Operation FILM CAM
REC Format PH1080/24P
Detail Level -4
V Detail Level -4
Detail Coring -2
Chroma Level 0
Chroma Phase 0
Master Pedestal 0
DRS OFF
Gamma SD NORM
Knee LOW
Matrix NORM1
Skin Tone DTL OFF
One other thing… For the highest quality images, shoot at 1080P, not 720P. If you want to release a final product in 720P, downsample your 1080P edited master. I don't want to start a controversy, but virtually every major TV show and TV commercial, whether originated in 35mm or digital, is post-produced and mastered in 1080P.
180 degree shutter
Scene Select F1
Operation FILM CAM
Detail Level -4
V Detail Level -4
Detail Coring -2
Chroma Level 0
Chroma Phase 0
Master Pedestal 0
DRS OFF
Gamma SD NORM
Knee LOW
Matrix NORM1
Skin Tone DTL OFF
