Luc Desjardins
Hi everybody!
Recently I tried to match up the white balance between DIY LED panels and regular Daylight / Tungsten lights, within my AG-AF100.
This proved to be impossible for two reasons:
1 - As I could manually set the Kelvin portion of white balance (From Blue to Red), I could not set the Magenta to Green color balance setting (hue, chroma phase).
The DIY LED panels I was given for testing were very blue, but also had a clear Magenta hue, which I could only correct using Auto White Balance (Chroma Phase seems ok for fine tuning, but lacking for serious color balance settings).
This would be fine if I only used those light, but when it came to match it with other color temperatures, another problem arose:
2 - When doing auto white balance, I could find no way to see what Kelvin setting the camera picked, neither could I see what Magenta / Green balance setting (hue, chroma phase) was selected neither.
Because of that, It was impossible for me to guess how much CTO stops to use to filter the blueish hue of the LED Panels to a normal 5600K (for example), and furthermore, it was also impossible to know how much Plus Green stops I would need to filter out the Magenta hue.
But maybe the AG-AF100 can't really help me in such "advance" filtering and white balance matching.
Is there a specific tool that exist to precisely measure the color profile of a light, so as to know how to filter it to daylight or tungsten, and so as to know if I need any plus or minus green, and how much?
I certainly hope I am making sense, since it is not the easiest problem to explain.
