AF100 setting- cooler?
You can bias color temperature in two ways. The first method is used when you're manually white balancing on either the A or B setting. You do this in the Menu under Scene Filer, and select
Color Temp Ach or Color Temp Bch. Then adjust in your desired warm or cool bias. The second way is to use the PRST white balance mode, and select VAR. Adjust your color temp to 5600K to
start and then incrementally however you wish. You can't however bias the fixed preset 5600k or 3200k values.
