RandyVideo
I am a new AF100 user. I am currently using the standard Lumix 14-140 lens. I have a 35mm Nikkor for my Nikon D5100 DSLR. It is good in low light. Does it make sense to use the AF-S Nikkor 35mm f1.8 G glass on the AF100?
With a proper adapter, absolutely. I recommend the Novoflex. A little pricier, but they have an aperture ring that will allow you to use Nikon "G" glass.
I want to ask about this. So, you have no indication of what aperture you're currently at with the "G" glass adapters, but how much of an issue is that really in practice?
The issue with using lenses that can only be controlled electronically is that when using a mechanical adapter you will not have control over your aperture. There are mechanical adapters with an aperture ring built in but it's a compromise at best. It will only control your brightness and it's not really the same as a real aperture on the lens at all. The adapter will vignette at some point and most importantly will have zero effect on your DOF. You will always be shooting wide open. With a F1.8 lens for example this means quite thin DOF which you may not need or may not want if you're trying to keep up with somebody walking for example...
This is completely incorrect (at least as far as Nikon lenses go).
With my Nikons and Novoflex, I physically control the the lens iris. I have also tested this on "G" lenses (which is what the O.P. was asking about) and that is also the case. There is a small tab on the lens a Nikon camera body uses to open and close the iris. The Novoflex is designed to also use this same tab to open and shut the iris.
I can't speak about Canon lenses as I don't use them, but with the Nikons the O.P. was asking about, a Novoflex (or any adaptor with a similar design) will in fact control the lens aperture.
