AF100 / nanoFlash 24p Workflow - My Best Guess
Will Clegg
So i'm about to start filming a documentary in NC and I'm using my AF100 and nanoFlash for recording. I have shot some footage already, using the 100Mbps Intra-frame option on the nano, with 23.98fps in a 59.94 stream, then transcoding to ProRes for editing and removing the pulldown as I transcode. Pretty good results. Not the most efficient, I know, but it works for me. I would love to record in 24pSf mode, but for some reason I cannot get the HDMI out on the nanoFlash to work with my monitor when I do that.
This is the workflow I have settled on for the bulk of this documentary shoot - please let me know if you think this is could be improved:
1) Shoot with AF100, using SDI out to nanoFlash, recording 23.98fps in a 59.94 stream at 100Mbps Long GOP (XDCAM HD 4:2:2)
2) Dump footage from CF cards to hard drive
3) Transcode using Compressor to ProRes (HQ), removing 3:2 pulldown during transcoding
4) Edit, color correct, and finish in ProRes (HQ)
I am not too worried about running out of CF cards as I have 3x 64GB cards and 2x 32GB cards, giving me about 320 minutes of record time at 100Mbps. Drive space not a problem either as I have two 8TB drives for editing (one is a mirror backup of the other).
Looking for constructive feedback on this workflow, if you have any. Changing the camera and recorder are not options, so please keep that mind. Thanks!
Probably rather light - mostly corrections more than grading for the interview footage, but maybe some heavier grading for b-roll (which I could shoot a higher bit-rate, I guess). ProRes HQ at 1920x1080 23.98 has a data rate of 176Mbps, so I figure that's pretty good to be working with at 4:2:2.
.... I have shot some footage already, using the 100Mbps Intra-frame option on the nano, with 23.98fps in a 59.94 stream, then transcoding to ProRes for editing and removing the pulldown as I transcode. Pretty good results. Not the most efficient, I know, but it works for me. I would love to record in 24pSf mode, but for some reason I cannot get the HDMI out on the nanoFlash to work with my monitor when I do that....
Will,
Do you mean you're transcoding and removing pulldown within the nanoFlash? Some HDMI monitors will not understand video if the pulldown has been removed. My IndiPRO Pro5 LCD monitor would not. I had to use the e-to-e setting on the nanoFlash in order to see the video while I was recording, but there was no way to review the video on the IndiPRO after it was recorded. I needed to replace that monitor with one which could handle video with or without pulldown. Looking at the specs for various monitors, I found that the Marshall V-LCD51 5" monitor could handle both 24sF and 23.98sF (the sF stands for segmented frame, which is missing the pulldowns). I got the Marshall, and now everything works great!:thumbsup:
http://www.bhphotovideo.com/c/produ..._LCD51_LPE6_BK_5_MONITOR_w_PRE_INSTALLED.html
-- Ken
P.S. -- I should add that I'm using a PC with MXF files... no ProRes involved. But I don't think your issue is with ProRes, just pulldown.
P.P.S. -- My appologies, I just now noticed that you're doing transcoding in post, using compressor. :undecided But this still sounds like a pulldown issue.
Yes, when I record in the psF mode to the nanoFlash, even using E to E I cannot see the video on my external monitor (SmallHD DP4) - did not even think about trying to play back footage. I am stuck with the DP4 for now, so that's why I am recording in the 59.94 stream.
Will,
Looking on the SmallHD website, I see that it has HD-SDI input. That should work, taking the HD-SDI output from the nanoFlash. Although I don't understand why the HDMI doesn't, at least during recording, using e-to-e. Maybe a setting on the nanoFlash or on the SmallHD needs to be changed.:huh: Sorry, wish I could be of more help.
-- Ken
Thanks for your reply - the model I have only has HDMI input, unfortunately. I usually shoot 29.97 and so this is not an issue, but want to make this doc in 23.98. Even if I could record in psF mode, I'm pretty sure I would want to transcode before editing anyway. Long GOP is great for acquisition, but not so much for editing, especially when dealing with high data rates.
If you're shooting for any kind of feature-length doc, I think you're merely setting yourself up for some frustration given the workflow you've established. That's quite a lot of footage to record, store, and then transcode (and storing both sets of footage, ProRes encodes are not perfect 100% of the time) for what seems like relatively little benefit over native AVCHD recording.
Thanks, Gary. In the footage I have worked with so far, I see a pretty big difference when color correcting AVCHD vs any I-frame codec. The color space difference is the biggest deal to me, but the data rate is significant too. I like to have as much leeway as possible in post.
I am estimating approximately 40 hours of footage, so about 1920 GB of nanoFlash recording, plus an additional 3360 GB of ProRes once transcoded. That gives me almost 3 TB of free space on the drive (on an 8 TB drive) to work with, and I can keep everything on one drive. Not too bad, I don't think. The drive is 7200 RPM and has eSata hookup, so it shouldn't choke my Mac Pro.
Where do you think the biggest frustrations would come about, specifically? I haven't shot a feature since 2004 when we were using DVCProHD, and that was relatively easy to deal with of course.
You should double that on an entirely separate drive, unless you're talking about a RAID 5 setup. And even then you might want to think about at least duplicating the nanoFlash recordings on an entirely separate unit if at all possible. I've lost entire projects before and it's not a feeling I'd care to revisit.
Well, the big one was storage, but it sounds like you at least have enough space to handle that (sans backup which I have no info on). The next would be transcoding. Depending on what system you are going to use, that could easily turn into days of straight processing. Best bet would be to use Red Giant's Grinder software as that's the fastest way to transcode into ProRes that I've found. Never had any quality issues with it so far, unlike FCP's Log and Transfer. I'm assuming you're using Final Cut. If you happen to be using Premiere, I wouldn't transcode because Premiere can natively handle the .MTS files that the nanoFlash will spit out, but have to go through the 32-bit QuickTime engine for ProRes. Just an FYI.
Outside of that, if you're able to get everything transcoded and backed up properly, it'll probably be smooth sailing outside of that. I think you'll find your experience very similar to cutting DVCPRO HD back in the day. Never had a problem in dealing with ProRes files once it's all said and done, and it doesn't stress your system, which is nice, unlike some of the more modern acquisition codecs (especially AVCHD).
I will definitely check out the Red Giant software, thanks for the tip!
I do have a second 8 TB drive that I will use to back everything up bit for bit.
I'm either going to edit in Final Cut Pro 7 or in Avid MC 5.5 (which won't handle AVCHD - at all). So I may end up transcoding to DNxHD 175 and editing in Avid, but FCP is more likely at this point. I was thinking of using Compressor to transcode everything since it includes a pulldown removal option and I have done it with a few short interviews with no errors.
Thanks again for reading and responding.
Hey Will,
I use my Nano with my AF as well. Here is what I do:
Af to Nano record 140mbps I-Frame, dump to hard drive, edit as XDCam then export to whatever the client wants. It seems that extra step may not gain you much (going to ProRes).
turn on the E to E on your nano, might bring up the monitor over your HDMI when in 24psf, skips the nano from the monitor, instead just seeing exactly whats coming out of the camera
@James - I have to do some kind of conversion to remove the pulldown, that's why I added in the step of converting to ProRes. If I could record in psF mode and have my monitor work, I would just record I-frame 180Mbps in the nanoFlash and that would be that, no conversion necessary.
@Scott - I have tried E to E, see previous posts. Still doesn't show anything on my monitor. I think it's an issue with the capability of the Small HD DP4 monitor.
Thanks, guys.
