So I got to use the AF100 for the first time. I have to say I'm both positively and negatively surprised. Positively because the camera was a total joy to work with, in most cases. I love having features like the built in waveform. But there are a few things that I didn't like at all, which I hope was just operator error.
1. The focus assist is plain horrible! Plain and simple. I don't know how else to put it. Coming from an EX3 which has a fantastic focus assist this just doesn't cut it. Yes I know about the flashlight workaround trick to highlight the eyes, but what about wide outdoors daylight shots? Sometimes the dreaded thin and weak red outline would just not show! No matter what I did. I tried the EVF detail peaking and it wasn't much help either. I looked in the menu and manual to see if there is a way to increase the red outline intensity, ala EX3 and there doesn't seem to be one. I turned the EFV to black and white and it didn't help much either. I have no idea why Panasonic would leave the magnifying option off the camera, but this is not cutting it. Are there any other tricks I can use to get better and easier focus?
2. Am I right that both zebras wont show at the same time ? You have to toggle between Zebra 1 and Zebra 2 but can never see both at the same time? If so, what a downer! Specially in day outdoor shots where you normally need to find a compromise it's very useful to see both.
3. I had the zebras set to 70% and 95%, but yet, the same place that would show 95% zebras would show 70% zebras and basically in the same amount once I toggled to it. There was basically no difference between 70% and 95% . I got pretty much on the same places and amounts. Is this normal? Normally the 2 zebras settings will also look very different in other cameras, with one of them being much thicker and also reversed to make it easier to differentiate.
4. The highlight handling is horrible, dreadful, absolutely repugnant!
Please tell me it was operator error. I had the zebra set to 95% to make sure not to blow anything. But once I got back and watched the footage on a bigger screen, it's full of ugly, electronic looking, plastic, yellow blowouts. Yes, I used the waveform. So it basically blows out at 95% as well. Also any highlights on the cheek, face, fingers etc look like it was shot with a $200 consumer camera. You absolutely can't let anything blow, not even specular highlights or it ruins your footage. I thought there would maybe be a way to turn down highlight saturation but couldn't find it in the menus. Is there a way? What can I do to get decent highlights short of terribly underexposing all my stuff? So far I have to say I'm disappointed with the camera. I wasn't expecting it to handle like a $10K camera but so far it's not handling even like a cheap $200 camera. I'm hoping somebody will hope in here and call attention to how dumb I am and how much I did wrong and all is operator error. As it stands it's truly sad.
I used the Abelcine Range cine file.
