AF100 mode switching issues
Inger
Whenever I switch modes from Cam to PB to view recent shot footage, then back to Cam, the IRE seems to clamp or limit to about 85 or 90%. I have to go into the menu and select DNS or something get it back to full range.
Any ideas?
Inger
not sure how to reset the camera as you suggested. will this loose all my scene files? anyways, this happens constantly even when i power cycle and pull battery. (edit) after i cycle the mode in which makes it limit, i can power down and up which will get it back to normal. However if i cycle the mode again, i have to either power down or go into scene file and play with the settings to make the IRE not limit... makes sense?
Well I think I have found a fix for this issue. If i have the the DNS to any setting other than OFF, it clips at about 85 IRS, when i select from CAM to PB and back again. Once I select the DNS to off in the scene file, I do not have an issue.
I don't know why, but that's not for me to figure out, but hope it helps someone else if they are experiencing this problem.
