[FS: General] AF100 Custom Pro Cinema Package 4:2:2
Sean A. Stencil
Af100package01.jpgAf100package02.jpgAf100package03.jpgAf100package05.jpgAf100package06.jpg
21 photos of complete package can be seen here.
For sale: Fantastic cinema camera package that is virtually new. Camera has 29 hours of use.
Includes:
AF100 Camera Body
nanoFlash 4:2:2 1080 Recorder Bundle
Nikon Nikkor 35mm f 1:2.8 prime lens
Nikon Nikkor 50mm f 1:1.8
prime lens
Nikon Nikkor 105mm f 1:2.5 prime lens with original case
Nikon Nikkor 35-135mm f 1:3.5~4.5 zoom lens with original case
Nikon lens mount for AF-100
Pro Digital Swing-Away Matte Box
ProAim Follow Focus Unit
2 12-volt nanoFlash Batteries
2
nanoFlash Battery AC Chargers
2 nanoFlash Battery DC Chargers
nanoFlash Bracket for 15mm rods
nanoFlashBattery Bracket for 15mm rods
1 Genuine Panasonic Camera Battery
2 Genuine High-Capacity Panasonic Camera Batteries
1 Genuine Panasonic Camera Battery Charger/AC power unit
2 SanDisk 64GB CompactFlash Memory Cards Extreme Pro 600x UDMA for nanoFlash
2
SanDisk 64GB SD Memory Cards for camera
CF USB Card Reader
Baseplates & 18" 15mm Rods
Hoodman for LCD
6' BNC cable
12" BNC cable
Accessory Bag
Camera Remote Control
Removable Camera Hand Grip
The AF-100 Book
AF-100 manual
Original packaging
Price: $8
,995 (inc. shipping.) Paid $11,000+ new. This unit is in perfect working order. Unit has never been dropped or mishandled. System has been babied and shoots amazing images! The 4:2:2 color space of the nanoFlash system provides ultra clean green screen keying! The 4 removable lenses included allow for cinema-quality depth of field and image control. If you are looking for a pro system, this one is ready to go! The project that this system was bought for was cancelled so it is now available to you.
While the tripod is not included, everything else pictured is. Please see photos.
The nanoFlash Bundle from Convergent Design records video, audio and timecode from an HD-SDI stream onto readily available CompactFlash (CF) cards, employing the high quality Sony 4:2:2 MPEG2 codec for compression. Boasting an incredibly small size and super low-power consumption, the nanoFlash stands poised to revolutionize the broadcast video industry.
This camera-mountable device is a miniaturized version of the award-winning Flash XDR, and has two CF card slots plus embedded audio support. The nanoFlash can be powered from a camcorder battery (6.5-20VDC) or the included AC power supply, and records 1080i60/50, 1080p30/25/24 or 720p60/50 at full raster 4:2:2 MPEG-2, at 50/100 Mbps (long GOP) or 100/160 Mbps (I-frame only). As both a recorder and player, the nanoFlash sports HD-SDI I/O as well as LTC in, wired remote control and a power/start/tally light connector.
Along with the AC power supply, this bundle includes a hotshoe ball mount for mounting the nanoFlash to the top of your camera, a CompactFlash card reader, and the requisite power and I/O cables. All you need is a camera and memory cards, and you're ready to shoot!
Records To Readily Available CF Memory Cards 32GB Compact Flash cards, available for a fraction of the cost of other professional video cards, enables 140/70 minutes of record time of high quality 50/100Mbps 4:2:2 footage per load of two cards (bit rates above 100Mbps require the 300X 16GB CF cards). Unlike FireWire based hard disk recorders, which merely copy the native camera video quality, nanoFlash can encode a live camera's "never compressed" HD SDI output to a much higher quality, higher bitrate with less compression, eliminating most of the mosquito noise and blurring artifacts. Full raster 1920x1080 (as opposed to 1440x1080 or 1280x1080) processing, coupled with 4:2:2 color (instead of 4:2:0), greatly improves horizontal resolution as well as keying and compositing operations. Optional ASI I/O Firmware Upgrade nanoFlash can be further enhanced with an ASI I/O firmware upgrade (pricing TBD). ASI I/O (MPEG2 TS) enables use of nanoFlash in HD ENG/EFP (live news coverage) and video over IP applications. Programmable bit rates from 17.5 to 100 Mbps easily support microwave and satellite transmissions.
Professional Swing-Away Matte Box with Side and French Flags
The Mattebox is specially designed and constructed of high grade machined aluminum, for all dv / hdv cameras with normal and wide angle lenses. It is precision engineered with a swing away mechanism for quick lens changes. The Matte Box controls light better than a regular lens shade and offers the videographer the ability to use high quality 4x4 and 4x5.6 filters for image effects. This matte box is easily detachable. It is light in weight but is made up of strong material.​
The sunshade mattebox is simple and unique in design and used to reduce extra sunlight on the lens. It works the same as a lens hood.​
Sunshade/filterholder features a non-reflective retangular shade that allows for single or dual filter applications. This Mattebox has two 4"x4" and 4x5.6 filter holders; perfect for polarizers and combination of square filters. The rotating filter holder enables users to eject or install square filters without disturbing the microphone or flash settings.​
The Mattebox with rod support attaches to the camera in such a way that only a soft foam cussioned lens ring (Donut) contacts the lens barrel, so you don't have to worry about your lens during the bumps and grinds of capturing exciting footage.
--------------- Matte Box Specification ---------------
  • 240mm x 150mm ABS sunshade​
  • High grade machined aluminum construction.​
  • Precision engineered swing-away mechanism for quick lens changes.
  • Compatible with wide angle lenses.
  • Industry standard height with +/- 10mm adjustment.​
  • 2 dual-purpose filter trays, supporting both 4x4" and 4x5.6" filter sizes (rotating 360 degrees).​
  • Complete with top flag and two adjustable side flags in aluminum (all detachable).​
  • 4 neoprene donuts to fit lenses of varying diameters (diameter of openings 51mm, 64mm, 76mm, 102mm).
