AF100 Card Slot Auto Switching
dafilms
I recent received my AF100 which is looking like an awesome alternative to my HVX200. One thing I can't seem to figure out is why the camera does not automatically switch from the first card to the second card when the first card fills up. Is there a setting for this somewhere that I'm not seeing?
StephenM-
Thanks. It looks like RELAY REC might do the trick. At first the option was greyed out and I couldn't change it. I switched REC FORMAT from PH 1080/24P to HA 1080/60I and I was then able to change the RELAY REC setting to ON. I then switched the REC FORMAT back to PH 1080/24P and the RELAY REC setting remained ON. I not sure why I needed to do it this way but it worked. Maybe someone else has an explanation.
It wasn't grayed out for me in PH mode. I did notice that when I put both 16GB cards in mine it still showed only 1h 30m as available recording time. I had to turn the camera off and then back on before it finally showed 3h recording time available.
