AF100 Audio Question
Hey all,
I'm loving my AF100! 2 quick questions though..
I've noticed when I import my audio into Premiere Pro CS5 the audio has been recorded to 1 stereo track (The internal mic and my shotgun mic have merged into one stereo track) ...yikes!
Is there a way for the AF100 to record each input to a separate audio track? Like if I was using a Sennheiser EW100 lav in Channel 1 and a Sennheiser ME66 K6 shotgun in channel 2.. I
wouldn't want those two channels mixed together into a stereo track..
Quesiton 2:
How can I set up the camera to switch to the second card in slot 2 while recording (First card is recording, it fills up and then it switches to the second card and continues recording without a frame lost)
Is this possible?
Thanks a lot
Will
I don't use Premiere - but in FCP the 'Stereo Pair' can be delinked giving you two mono tracks, I do it on every import. Relay recording is possible; just look for relay recording in the set-up menu and switch it on.
G.
Q1. You need to select the mics or inputs by using the Input Switches correctly for your purpose and requirements.
