Now that i had time to make more tests, here some files i recorded with the Cam and one File recorded with the DR100 in the same room.
The noise level in your sample WAV files is about the same as my HMC-150 camera, which has a noise-floor of about -63 dB, which is not great, but not terrible. ( Your #4 file was very noisy, showing a noise-floor of -48 dB )
I haven't had a chance to test the AF-100's audio capability yet, but I would recommend that you try using a good field-mixer ( any of the Sound Devices mixers are excellent ) and record LINE level signal from the mixer with your AF-100. ( so mics are plugged in to the Sound Devices mixer, and LINE level audio goes from the mixer to your AF-100 )
Also, make sure you calibrate the AF-100 audio channels by feeding a 1 kHz test tone from the mixer and adjusting the camera audio levels until the test tone shows as -12 dB. This should produce the best noise-floor possible with the AF-100.
Any tips for a small, cheap mic pre that i can mount on the cam ?
Measurement 1: Line Level, no inputs, gain 5
I get nearly the same results. I compared with your files and used the same adjustings you used.
I only posted one measuring result. Thx for uploading them.
Now i know that the noise is normal. Any tips for a small, cheap mic pre that i can mount on the cam ?
THX
