Jim Brennan
VHS Member Old Skool
Agreed, but it is nice to have a lens to do most of your heavy lifting...especially if you are on a tight budget.
Gimme some time and I'll shoot some side-by-sides.
Not really. Because you can't compare one to the other to the other in different tests. The only way adding the AF100 into that mix could have any relevancy, is if they were all tested simultaneously under the same conditions.Thanks Barry. I'll look forward to that with great interest. I've been doing side by side comparisons of DSLRs (5D2 and 7D) with the HMC151 only today, so having the AF-100 to compare as well would be very useful.
Still uploading.Wow Barry. Thanks for the test. My guess was pretty close to what you discovered. Did I miss the link to the video? It must be still uploading.
Barry... Can't you adjust the sensitivity on the AF100 by ISO? dB is so lame and video-y?![]()
So is the AF100's cleaner CMOS sensor able to withstand an additional 9dB of gain? I guess that's the question you want answered, as that 9dB equals about 1.5 stops, and the lenses are about 2 stops different. 18dB of gain is a lot though; that's the same as ISO 3200.
I.
From a $5k camera? You were dreaming, really.
Correct. 1/2-stop sensitivity = 3dB. 6dB for a full stop.I always thought that in video each 3db is a stop, is it only 0.5 stop?
We all think that. But the reality is that a 5x zoom at a constant 2.8 costs $10,000 to $40,000. So, keep dreaming, we'd all love that lens. At least, until they delivered it -- then we'd start screaming about why is it only f2.8, why isn't it 2.0, etc...I too think that a 1500-2500 dollar zoom that's maybe 8x with a constant 2.8 would be ideal... Especially if it's with free flowing F-stops and not increments..... Well one can dream.
Point being, did I have my HMC set up exactly the way you had yours? If not, then there is no conclusion that can be drawn, relative to your other test. See what I mean?This is true for 'absolute' relativity, but using the HMC as the 'base line' in both tests will at least give some 'indication' of relativity which is all I'm really after at this point. I'm looking for how the AF compares to the HMC not how it compares to the DSLRs. Hopefully that makes sense.
Do they? Most of the Canon DSLR performance is due to having a faster lens. Most folks I know say they wouldn't want to push the Canon any faster than 640 ISO -- which is only 1/3 stop faster than an HMC150 at 0dB.Well you would think It's should be possible if the Canon SLR's can do that well in low light.
Footage files:
(and yes, the disclaimer: this is the worst AF100 footage you will ever see in your lives, shot under the worst possible conditions, +18dB of gain/3200 ISO with a pig-slow lens)
HMC150, wide angle, +9dB, wide-open f/1.6: http://www.mediafire.com/?c6qk8v795ax1oqa
AF100, wide angle, +18dB, wide-open f/4.0: http://www.mediafire.com/?jl41s3x7yt2hbq6
HMC150, telephoto, +12dB, wide-open f/2.8: http://www.mediafire.com/?p959373ua15m5z8
AF100, telephoto, +18dB, wide-open f/5.8: http://www.mediafire.com/?v77nvo4h2qbhx4d
And, lastly, the AF100 more the way it was meant to be done: +3dB, with the 20mm f/1.7 lens. Which would have been 0dB with a 1.4 lens. http://www.mediafire.com/?602y1o9jeg4wh29
