Duke M.
The first thing I noticed is the release notes recommend the camera be on AC instead of a battery. I presume the upgrade takes awhile and this is so the battery doesn't die in the middle of it.
It looks like the EX1 BC-U1/U2 Battery Charger will work with the Swit single pole to XLR adapter. Does anyone see a problem with that?
The second issue is that it says after formatting the SxS card in the camera is should be inserted in the computer to copy the bin file to the SxS card. Plenty of SxS cards, but neither my computer nor my two multi card readers support SxS.
Do you suppose its okay to leave the card in the camera, connect a USB cable and drop the binary file onto the SxS card there?
