Ceri Allen
Hi
I need to capture footage live as its being filmed on a DVX100. This is the first time I have both captured live and worked with footage from the DVX100! So I really want to be sure about the workflow.
Will be capturing on macbook pro laptob, FCP 7.0 via firewire. Am unsure if it will be shot 24p or 24pA, but would like to know what the set up is for both possibilities.
As far as I understand:
Sequence preset: DV NTSC-23.98
Capture preset: DV NTSC 48 KHz for 24p or DV NTSC (2:3:3:2) anamorphic 48 KHz for 24pA
Device control: Non-controllable device
Then I simply hit capture now when rolling and esc when cut.
Is this correct and are there any known complications that you can pre-warn me about?
Ceri
Ceri
