I'm all for spending less ff I'm not going to see much benefit from recording 4:2:2 and getting the less expensive field monitor
1. What size TV do you consider "really really big"? What happens when viewing 4:2:0 on such a large sized screen?
Thanks.
There is a huge difference between 4:2:0 and 4:2:2 that is definitely worth spending money on,
with 4:2:0 footage, the colours are thinner and visually much less satisfying, really see it in reds and skintones - there's a richness there in the 422 colour palette that looks so much better,
I really noticed it going from the Panny HVX/HPX P2 422 series of cams to the HMC SD 420 cams, its hard to describe but once you've seen the difference its hard going back to 420.
The trick is to nail the colour in camera. If you don't 4:2:0 8 bit doesn't leave you much latitude to yank on the sliders in the NLE or POST. Mike does have a point BUT you have to nail the colour in camera or things can get get ugly on unsalvagable. 4:2:2 10 bit generally allows you latitude to pull colours and possibly chroma into line, when the original footage is not close to reality or intended tone and colour.
Lighting is also a big part of the picture, in terms of the potential degree of success that you are going to have with your shooting. You control your light and give it enough, working with your footage successfully is going to be way easier and give you more of a chance of success.
Of course, these are huge generalizations but enough light in the right places is going to have a bigger detminate in the success of your footage than almost anything else. 4:2:0 and 4:2:2 be damned in relation to the power of light and in the correct places.
Same. It's not just the technology gap. You can see it with footage from an XF100/300.Have to disagree on this Mike, I can be cynical about "motion cadence" and other pixel peeping jargon but there's a glaring visible difference between 420 and 422!!
As others have said, that wouldn't be a valid test, because everything else changed between the two cameras too.If i get time over the next day or two i'll post a still of the same shot from my AF101 (AVCHD 420) and my EVA (Long GOP 422) and get your opinion on the differences between the two, i'd be surprised if you cant see the benefits of the extra colour in there.
While I don't doubt you see a difference in the color space between the two cameras, it's probably worth considering the 7-8 year gap between the two pieces of technology. For very high end cameras (ARRI) there are less differences over the years, but I'd assume everything is astronomically better on the EVA1 vs. the AF101, including the sensor and other hardware, processing, resolution, colors, etc.
