Great jib for sale. I have only used it a few times over the last few years.
It's better than most other jibs because it allows for full fluid pan and tilt control from the base of the tripod.
The unit was 3500 new with all the added lengths and the tripod base. Asking $2100.00
Prefer Local LA area sale.
http://www.advantajib.com/video.html
● 10ft reach (1.2m)
● C/W : Pan & Tilt/ Roll Head
● Fulcrum
● Panhandle Weight Bar
● 3 cam C.B Springs
● Leveling Bar & Cable
● Video & LANC/ Pani. Remote Extensions
● Quick Release Sliding Camera Shoe
● Pelican Case with wheels
This jib is in a class by itself other jibs use cable-drive systems to pan and tilt. These systems can be cumbersome, time consuming to install and balance, and not very smooth. Because of their push/pull cable-drive system, friction increases with distance, making smooth pan/tilt starts difficult at greater jib lengths. The Advanta-Jib Lite's patented hydraulic tilt and open cable pan system allows for smooth pans and tilts at any height - giving you more freedom and flexibility, taking your productions to the level you've always dreamed of.
Advanta-Jib Lite provides an edge that'll set your productions apart.
● 10ft reach (1.2m)
● Fulcrum
● 3 cam C.B Springs
