Postmaster
Dark Side of the Camera
Looking good so far, can´t wait to get my hands on Prelude and Speedgrade.
http://success.adobe.com/assets/en/downloads/guides/SG_CS6_Intro_Reveal.pdf
http://success.adobe.com/assets/en/downloads/guides/PL_CS6_WN_Reveal.pdf
http://blogs.adobe.com/premiereprotraining/
http://blogs.adobe.com/toddkopriva/
http://blogs.adobe.com/insidesound/
CS6 Production Premium will include the following applications:
• Adobe Encore CS6
• Adobe Media Encoder CS6
• Adobe Story Plus
• After Effects CS6
• Audition CS6
• Photoshop CS6 **public beta announced March 21
• Prelude CS6
• Premiere Pro CS6
• Speedgrade CS6
New to the suite are Adobe Prelude, an ingest and rough cut application and Adobe Speedgrade, an amazingly powerful color correction application. OnLocation doesn’t seem to have made it into Creative Suite this time around.
Throughout the Suite, the default interface is sleeker and uses a darker background and brighter colors to help put your eye where you want it. Dynamic Link works in the same way as in previous versions, but has been recoded to work much faster, allowing smoother workflows than ever.
Here are just some of the major features you’ll see in Adobe Premiere Pro CS6:
• An optimized Mercury Playback Engine that is faster than before in software-only mode, and also sports a broader range of choices in graphics cards. There’s even OpenCL support for certain MacBook Pro (TM) machines using OS X 10.7 that have AMD Radeon HD6750M or HD 6770M graphics cards with over 1GB of VRAM.
• Adobe Mercury Transmit gives Adobe I/O hardware partners, such as AJA, Black Magic Design, Bluefish444, Matrox, and MOTU direct access to the Mercury Playback Engine, so you experience better playback performance than ever before. When using external monitors, you’ll get full-screen playback while maintaining all the real-time performance benefits of the Mercury Playback Engine.
• The addition of Warp Stabilizer and Rolling Shutter Repair, which were previously only in Adobe After Effects.
• Unlimited cameras in Multicam.
• Many new and enhanced editing tools such as adjustment layers very reminiscent of After Effects, trimming directly in the Program Monitor, and a redesigned Audio Mixer. You can now double click to apply effects to selected clips.
• A redesigned Three-Way Color Corrector effect, that of course, uses GPU acceleration
• The redesigned Adobe Media Encoder is now fully 64 bit software with a much expanded preset list and more efficient batch encoding that makes multiscreen delivery a breeze.
After Effects:
• Native support for Adobe SpeedGrade .Look files, cineSpace .csp files, and overrange IRIDAS .cube files.
• Not only is Mocha still there, but you can launch it directly from within After Effects.
• Global RAM cache. This is a vastly improved frame caching system that allows you to try different options and Undo without a penalty in productivity, as well as render and cache a comp’s work area in the background.
• Persistent Disk Cache. Previews done in a previous session are saved and immediately available the next time you open a project.
• New graphics pipeline. With more efficient use of OpenGL, the work environment in After Effects is more highly responsive and smoother. You’ll get faster manipulation of layers with graphical overlays such as masks, motion tracker points, and motion paths. Depending on the hardware, functions may be speeded by anywhere from 1.5 to 16 times!
• A new intelligent 3D Camera Tracker effect.
• A new ray-traced 3D rending engine giving you the capability to quickly design fully ray-traced geometric text and shape layers in 3D space. Pair this engine with, say an nVidia Quadro 2000, and you’ll see over 10 times the performance over CPU-only rendering by a stock Intel i7 3960X processor!
• Variable mask feather lets you set any number of points along a closed maks and define the width of the feather on a per-point basis
• Pro Import, previously available as a separate product from Automatic Duck, is now included with After Effects CS6.
• Many, many effects that were previously 8bpc now support 16bpc or 32 bit float including all of the HD plug-ins of the included CycoreFX HD Suite.
