Adjusting headphone volume
Mark-P
I'm using an A7s2 with a small Sony preamp and boom and am pretty new to production. What do you set your headphone volume based on? Do you just set it to a comfortable level for listening and use the meters to adjust the actual recording level? What is the best approach to this?
Thanks.
Pretty much.
Meters only tell you part of the story: that something is passing through the signal path. Listening tells you the other 80% of the story: the quality of what’s being recorded. Noise, RF interference, and other things will make the meters bounce, but active monitoring will tell you whether or not it’s a clean signal being recorded.
So yes, use the meters to reach target recording levels and set your headphone monitoring to a comfortable level for active monitoring.
