DVX100Shooter
When adjusting audio levels through a portable mixer, what do you set the levels at on the camera? Do you just keep the arrows on the dials on the camera in the facing up position then control all of your audio levels from the mixer? Does the mixer bypass the dials to control audio from the camera?
Also, what is an example of when I would need to use Line level instead of Mic level?
