wanted to know from you have you ever used an adapter for Variable ND filter to fit in a smaller size lens. Never tryed and i was about to buy one.
Thank u so much
I have step-up rings glued to all my lenses, to make the front thread standard (in my case, 49mm for the very small lenses, 67mm for everything else; none of my lenses requires filters bigger than 67mm).
Depending on what camera you're using, you might need IR NDs (NDs that block IR light) which are more expensive, but also keep your footage from having a brownish red hue.
As for Variable NDs, SLRMagic is probably the best, GenusTech makes a pretty good one, Tiffen's probably about the same, Syrp is intriguing, but there aren't many reviews on it.
I use Hoya ProND filters. According to this thread, they are the best ND filters that don't cost an arm and a leg.
(yes, that's a 75-page thread about ND filters)
