Achieving subtle, soft lighting.
Just to get things straight...
"Pulling" film does NOT mean under-exposing the film, in fact it means the opposite. When you "pull" a film in processing, you are under-processing the film, which lowers the ISO of the film, so that to get a proper exposure with "pulled" film you have to OVER expose the film because the sensitivity of the film has dropped from the under-processing.
For example, a film that might have a normal ISO rating of 320, might have an ISO rating of only 160 when it is "pulled" one F-Stop in processing. The reason you "pull" a film is either trying to correct accidental over-exposure, or when you are intentionally trying to "flatten" the contrast of the film by over-exposing and under-processing it, which opens up the shadow areas and lowers the density ( brightness ) of the highlights.
While generally pull processing involves over-exposure, you can certainly pull (underdevelop) with normal exposure, or even with underexposure (although most thin negatives aren't exactly begging for underdevelopment). This is a common contrast control technique, esp. in b&w photography, but is also used with color film.
You would then either print up (normalize) by adjusting printer lights, or simply print normal going for a darker look.
Got a huge room? More fabric and more lights.
It's not really "costly"
Er yep, more time is costly
Its also really hard to pull on a wide, getting into those corners
And more lights, as soon as you cant pull of the domestic circuit.. to me thats costly if you need a genny, and often security for it
Of course a few k of tungsten or HMI is not costly compared to a name actor, or a tecnochrane, or (and Ive seen this done) jacking up a first floor of a building with scaffold to accept the weight of a PeeWee which took days to rig.. or
Gamma is wrong on your examples, its not full range from 0-255 but its 16-235, they should not look like that.They arent flat(maybe 2 examples are lighting wise) most pics have rembrandt lighting but theyre like behind some fog which is ugly and i dont like it, its problem with 16:235 range, should be full 0-255.
HEre is corrected but after operation like this codec is more and more visible, gamma was shifted in many of those screencaps.
attachment.php
Most players will display the legal range correctly spreading it over the full output range of the device. In fact, by standard for home video (blu-ray) the images should be with luma 16-235. But yes, a jpeg screenshot should be converted to 0-255 to be comparable.
On the other hand, some of these caps obviously have values below 16, so they are probably correctly captured by the capturing software.
I hate the word 'aesthetic' - because to mind it suggests beautiful, pleasing, and other positive words. I can't apply it to dull, flat, and old fashioned in any sense. Of course there's a need for a look for certain projects, but dirty, gritty, old etc all conjure up for me negative. The only time I see it look pleasing is in stuff like Blade Runner where the treatment really works by using dark to not mean dull. Isn't it difficult explaining this in words?
