Thanks for the reply.
Are you suggesting an ACES workflow does not work correctly outside of a raw workflow (from camera) or more that to use an IDT properly you need to be shooting RAW?
The software in my case is DaVinci and Nuke both of which support ACES, its a pipeline experiment vs any kind of LUT slapping for now.
This becomes a bit more of a resolve question but has anyone used the aces workflow with slog2 and aces in resolve?
i'm booked to grade a web series next week, and was testing the footage in ACEScc this evening as i normaly work with that, but i also normaly work with footage from Alexa/raw or Dragon.
I'm seeing a great starting point (and got to it very quckly) by using the Slog IDT with ACEScc in Resolve. I'm also not seeing any quantasion errors were clearly visable with any of the LUTs i have.
If i was going to work in display refered i would run far far away from any of the LUT's avb, they do nothing you cannot do in seconds with hands, eyes and scopes... and they do create issues , some create significant issues - some create less trouble, but all of them, every single on that i have create some damage to the image, utterly needless damage.
I agree wiith Paul, RAW workflow is preferable in ACES, log encoded footage has less to gain as it's already had the dynamic range compresed to match a display refrered workflow, where RAW from a camera capable of recording 16 stops has the most to gain by a scene refered workflow.
i use a three node basic set up, first node uses SOP+s, second node uses L*A*B*, third node uses RGB with luma mix set to 0, there i mainly work in primary bars, and almost never touch the hue offset balls, have all three of their sensitivity controls set to "1"
the choice of ACEScc for me is more about using the workflow and tools i'm comfortable with, and perhaps cleaner color seperation than it is about leaning on the imense highlight control you have with RAW in ACES
Thanks Dermot.Nick Shaw has a DRX preset on offer to move Slog in 2.4 gamma without clipping, crushing or quantasion errors.. look for "antler power grades", he should have these on his website sometime this weekend;
www.antlerpost.com
But i once reverse engineered the koji fuji film emulation lut in under 15 min just to prove a point.... it can be done, and done qucikly if there's a reason to do that... i think the "impossiable to recreate" is more marketing hype and pixel peeping than the reality of sitting it the hot seat all day long... any of them are pretty easy to reverse engineer to a point that MARCIE is visualy identical, the reality i see is that none of them are hard to match, and nothing but good will come from throwing canned LUTs in the trash as fast as possiable!
Thanks Dermot.
Just to clarify, I have none of my recent stuff up on my website yet, and most likely won't do until the middle of next week. The Sony PowerGrade shown here is designed to match the LC709A LUT, but is a work in progress, and I wasn't planning to release that until I had done further testing. But if anybody desperately wants to buy it now they can contact me directly. It's the version which matches the standard Alexa LUT which is ready to buy now, and will be on the website next week.
Both the Sony and Arri PowerGrades are designed to match the stock manufacturers' LUTs but with the benefit that they don't clamp the output, and because they comprise a series of nodes which make up the transform, rather than a "black box" LUT, you can tweak the individual elements, rather than piling additional nodes on top of it to "fight" the look of the LUT.
