Ac adapter::: Urgent
No, it does not come with one. As with most broadcast camcorders there is an industry standard 4-Pin XLR 12VDC input on the rear. Lots of companies make power supplies IDX being one of them. If you need to go the cheap route you can always find a beefy 12v DC power supply and solder a 4pin XLR on the end. A few Anton Bauer products also have DC output, or you can go with a "Charger that mounts like a battery" AKA the "Anton Bauer Tandem".
I just use the 12v out (4 pin xlr), from my IDX charger (cant charge when you do so).
As an FYI, the battery power tap on the cameras battery mount does not work without a battery in place, just in case you had any need for it.
