AC Adapter Cable
There is nothing special about the cable its just an AC power lead, the connector that plugs into the charger is called figure of 8 here i sure it has other names.
Its used quite a lot on domestic kit VCRs / clock radios etc im sure if you hit the nearest hardware store they will have one.
Mind you my panasonic charger is different and its mains connector is know as a IEC again a very common connector
Yeah, I realized it was a common AC cable but I wasn't sure what it was called. More-so, I was mainly worried about getting a wire with the same specs. Thanks for the help Vultch.
