avatuar Well-known member May 9, 2006 #1 I am running vegas 5 and am wondering how can I export an AAF file from it to use with Avid. Does anyone know how to do this?
scharky Veteran May 9, 2006 #2 I don't know about Vegas 5, but in vegas 6 you can simply go to "save as" and then select the AAF file format.
scharky Veteran May 9, 2006 #4 Did you look through the help files? If it isn't in there, most likely it can't be done.
M m1best Active member Jan 4, 2007 #6 So say you burn the unrendered AAF file and open it in AVID, what does it look like, edits? how is it handled?
David Jimerson Administrator Staff member Jan 4, 2007 #7 Burn it to what? You'll need all of your original media files for it to do you any good in Avid; you can't just transfer the AAF file by itself.
David Jimerson Administrator Staff member Jan 4, 2007 #9 Use an external hard drive and keep everything on it.
