squig
Worse than the 5d2... don't want to move backwards. Do you guys have a measurement for the D90? Maybe it was around 40?
33
I couldn't use it as an A cam but it will certainly work as a B cam.
Just saw the D90 measured at 33, so the new Sony is in that territory. We had plenty of problems with the 5d2 at 25!
I'm very excited about the A7s, but it's looking more like a specialty item to me, not nec the do everything small cam.
What about this test where the APS-C mode was looking weak compared to the full frame mode?
The D90 was about 33 ms, the 5DII about 25ms, and the A7s is 30.5ms. I'm frankly a little surprised that Sony deemed that good enough to produce a camera in 2014. If it had been roughly like the 5D III (20ms), I would have been perfectly happy.
Some Sony representatives apparantly said at one of the trade shows that the RS should be tuned to at least match the 5D III in the final production/ firmware version. I guess that was either just to deflect the issue, or perhaps any faster sensor readout turned out to generate to much heat.
You always have some control, specially if you have resolution and sensor size to spare: you can also shoot 4K-FF and then crop 2x, which makes it 15ms
How does cropping 4k change the skew angle //// I don't get it :huh:
Rolling shutter time is how long it takes the sensor to go from the top of the image to the bottom of the image. On the a7s shooting FF, the last line is recorded 30.5ms after the first line was recorded. If you throw away most of the image and use only a small 2x crop from the center, your last line is recorded 15.2ms after your first line was recorded.
The angle is helped because you have to take this into account before shooting, and use a wider lens, and for the same motion you'll have less skew. If you want fast-RS 50mm, you shoot 4K FF with a 25mm and then crop 2x. It actually works, at the expense of resolution and DoF. You can test this yourself using any RS camera.
It's exactly the same principle by which the APS-C mode has faster RS but will require you to use wider lenses.
I've gone back and forth on this thing since NAB. Changing my mind almost everyday. I am beginning to think the cons are outwaying the pros here. It's great looking and a nice piece of tech for sure, but the quirks it comes with is starting to look equality as annoying. I was really excited when it was first announce because it sounded like a hurdle past other cameras limitations and really brought a lot of desired elements together. As usual though, it's a trade off. I know every tool for every job. This particular tool is starting to become clear of what it can and can't do. So far, not pulling the trigger yet.
It's typical Sony to lead with a headline feature only to disappoint in the overall package.
I'd rather have a well balanced camera than a camera great in one thing but be lacking in everything else.
On the other hand the A7S would be more attractive at $1200 and if it had better native lenses.
