chappelldigital
Hey
Curious if this is a problem specific to my adapter, or if all adapters are like this.
The tripod mount on the adapter isn't centered, so when I level the tripod, the camera is actually not level at all.
I can always level the tripod based on the camera's internal level, but I'm using the A7s as a B-Cam to my C100, so it will be on a slider a lot of the time. In order to level it to the camera's level, the slider slides on its own because the tripod is uneven... which is a bit silly.
I suppose if this is 'normal' the solution is a cage for the A7s or a battery grip? Currently I can't attach a QR plate direct to the A7s because the adapter comes down lower than the A7s base.
Thoughts?
Thanks!!
Thoughts?
Thanks!!
