I came across an issue I haven't noticed before the other day, jagged lines. I'm including an example of a project I'm working on, you can see the issue between 00:32-00:37 and 02:07-02:24. In the first part it appears on the metal stripe on the bottom of the TV, as well as the golden line on the wooden radio. In the second example it appears in the dark lines between the kitchen drawers. The video is shot in 4K through the Shogun in HQ. Picture Profile in camera was Cinema 4, Pro, Detail -2. After noticing I tried different profiles in the camera and went through different levels of detail but they all showed it to some degree. I also tried changing to a different lens but the issue was still there. And thoughts, ideas, or is it simply common knowledge that this happens?
https://www.youtube.com/watch?v=CsK7vtSFuvk&feature=youtu.be
