squig
Rolling shutter is bad but not quite a deal breaker because you can get around it if you're careful, but short of hacking the firmware there's no way to get around the ugly highlight aliasing. I urge everybody to contact their local Sony service centre and demand a fix for it. And anyone who wants to make negative comments about the likelihood of a fix or profess "it's not that bad" can save their breath. Sony fixed the physical clicking on the Nex 5n and I consider this a much bigger bug.
We should hassle Sony to do something about the 30.5mms full frame rolling shutter too. I'm assuming Sony have limited the sensor read speed to prevent it overheating, if that's the case they could add a "skew fix" mode with a faster rolling shutter (preferably around 20ms) at the cost of a shorter record time. Sony are clearly trying to market the A7s as a 5D MK3 killer for video shooters but it's a big leap backwards in terms of rolling shutter and highlights.
On a more positive note the second example clip shot at 60p doesn't appear to have any aliasing (apart from the highlight aliasing), other 60p clips I'd seen previously had nasty skipped/binned type aliasing throughout so I'm a bit confused as to why this footage doesn't. Post processing issue perhaps?
Can somebody test for highlight aliasing with external 1080p and 4k recording.
The following screenshots are 1920x1080 jpegs you can drag to your desktops for a closer look.
UPDATE: The highlight aliasing occurs in all movie modes and on external recordings. I've gone through every function on the A7s, nothing stops the highlight aliasing. It can be black, blue, or yellow.
