Hi what pp do you think is the best for having the most clean video in iso 50,000? or would no pp be the best? i dont really care about dynamic range or color correction flexibility, i just want the least noise possible.
a PP off profile would be good as it keeps the image pretty crushed. Neutral might be a good choice as it'll give you some ability to add contrast.
Best bet would be to do a quick 5 minute test and see what you like. As has been mentioned a million times, it's not necessarily the iso, but lack of light in shadowed areas, that increases noise.
Also worth noting that the ISOs mean different things in different picture profiles or creative styles. If you ETTR and correct for the difference in post they will all be about the same except that some will have shadows crushed out to different degrees.
Are you working with a fixed light level or a fixed camera ISO setting? a given ISO represents completely different gain settings depending on the gamma curve you've selected.
