we all know by now that a7rII can overheat when shooting internal 4K.
Any overheating when shooting 1080p?
p.s. as far as I see on these forums, a7s did not overheat.
Very likely a7rii shall not overheat in 1080p either.
Not many testers reports on that as the 1080p is markedly inferior to the a7s 1080p so 4K is the one being tested and tortured.
However, Sony's rarely overheat recording in 1080p (a6000,a7,a7r,nex), a tiny bit more incidents than bigger DSLRs but rare,
Why not modding the a7RII with a backplate or something to disipe heat?
I read an interesting speculative article on the overheating issue (can't seem to find it right now) where they suggested that the 5 axis stabilised sensor had to be free to move at high speed in any direction to accomplish the stabilisation, which would suggest that a heavy heatsink or other bulky thermal cooling solution would be difficult to implement. Without doing any research myself, I can see why that might be the case. Depending on whether it's the sensor or the signal processing circuitry which is generating the most heat, an external cooling mod may or may not improve matters.
