A6500 headphone output?
rawfa
I've been doing a lot of research regarding this and I've tried using an hdmi to vga adapter that has an audio output. I can plug in a headphone and listen to the audio that is being recorded, but as soon as I press record the LCD blacks out. So I was wondering what are my alternatives so I can actually hear the audio that is being fed into the A6500. I looked into the XLR-K2M and it would be THE perfect solution, expect that it's way too expensive. Is there another alternative? Are there other companies that manufacture audio devices that can feed the A6500 audio via hotshoe?
A monitor with no latency, maybe for around $200.
Sometimes you'll find a used BM VA for around $300, which is loaded with features, and will serve more than just an audio monitoring device.
