mainstreetprod
I'm considering a Tokina 11-16 with an Le-a2 adapter on my FS700 but can't confirm whether autofocus is supported yet. Anyone know? If not, is there a wide option that does have good AF?
Is autofocus really needed? If not you can consider some older SLR style zooms combined with a speed booster which would take an f2.8 zoom down to an f2.
cheers
Paul
Right now I'm still leaning toward the Tokina 11-16, but without worrying about autofocus. Someone has a Nikon version locally and I have an adapter. I think I can stop the Tokina down a bit and get enough depth of field to make focusing less of a concern. Main use for this is on a stabilizer.
It's a solid performing lens and if it's for a steadicam style arrangement that would work well.
One other thing to consider on a steadicam is some kind of emount autofocus lens. The benefit is the focus movement is smoother and very much depending on what you're shooting you may get results. For example i've had that sigma 19mm f2.8 on a jib so that it auto focuses as it's moved down. For that shot it worked well, it tracked the subject properly and there was no way to focus manually. I'm not sure whether you can program focus moves on the fs series? I seem to remember doing that on an EX1.
I think this is a big area for future development - programming focus moves, better object tracking and wireless control of lenses.
cheers
paul
