A new design Arri-style BASE & Dovetail
fss
Hello everyone, Allstar BASE & Dovetail were available!
The raw materials is 7075 aluminum comes from Switzerland, and did hard anodizing for surface treatment.
What is Hard Anodizing? http://www.wisegeek.com/what-is-hard-anodizing.htm
Price:
list price: Allstar BASE item code:AAB -$960 (including 2x 25cm super light 19mm aluminum rod) $-160 discount for old customers who purchased Allstar Dovetail before 5/20
Allstar ARRI Dovetail item code:AAD-1030 -$420
But now,this first 15 units of Allstar Base will be sold in $ 680 , and Allstar ARRI Dovetail -$350
(just this 15 units or I`ll broke!)
Please Email to me if you are going to order it. (fall in line by payment clear)
allstar.cine@gmail.com
About Allstar BASE : http://www.reduser.net/forum/showthread.php?t=28902
And other Allstar products:http://allstar-cine.myweb.hinet.net/html/red_accessories/red_accessories.html
Allstar Base is not only a high-quality Arri-style base, but also a specially design for Hand-held, especially on Epic and Scarlet. Because of the double dovetails design on Allstar Base, you won`t need to mount shoulder pad with the whole base, just use a 8mm high plate. So the optical axis of lense will be under your eyes, and save weight, which ARRI style Hand-held rigs can`t do it.
The basis of the render picture(released from RED.COM), you can see their new base "RED RISER" will higher than standard ARRI Base.
So if your Hand-held rigs was mounted by the base, you`ll get more 1.5cm or thereabouts heigh. The height will let you feel unstable easily. With Allstar Base there will be a 8mm high plate mounting under the camera. Even mount the shoulder pad under the modules if the space is enough.
