a little help importing tpe?
ok well i have avid mc and an hvx 200 ap and i am needing help importing tape footage into avid. when i set up the deck in avid there is no selection for my camera?
You are referring to CAPTURING correct? Import in an Avid is for electronic files, audio, etc.
Capture brings tape into the MC via firewire or component/composite or y/c. Assuming, your deck/camera is configured correctly to capture from it and you have installed the P2 drivers on your MC's computer (not sure if that even makes a difference since you've got tape). Should be as easy as a firewire connection, Choose CAPTURE from the TOOLS menu, choosing 1394 mode, then rocking (you may want to do an AUTOCONFIGURE from the CAPTURE drop down list).
