Hi everyone... Please help as no amount of books I am reading and hours testing can help as your experience can.....
I am wanting to purchase cool lights as I will be shooting at home and dont want to override circuits, etc., etc., As you'll see from the description of what i am working with its sort of complicated. I'm not sure what 3 point system wattage, spot lights etc to get. I will be shooting in wide screen (so I need to be careful with boom poles etc., getting in the way) using the dvx100 original with the anamorphic lens and the shooting environment is as follows:
*Approx space is 13-17' wide X 13" deep (however, I have an additional 15-20 feet of open space in front of this area)
*35' ceilings
*High ceilings have with 75 watt sylvania flood lights with 120 volt and is controlled via dimmer switches
*All walls have a faux painting containing tan, gold, and cream colors--no white anywhere
*3 dome windows with a red brick overlay around the windows--prefer windows to stay open to show greenery from outside. The larger dome window is directly behind the subject.
*Dark wood cabinetry + dark wood floors
*5' 6" feet of background space behind subject (person) which includes the countertop that has 2" cream tiles atop + chrome double sink
*In front of subject is an 7-8' wide X 4' deep dark colored (dark cocoa bean) oak wood counter with 36" black stove in middle. NOTE: There is a fan above this unit where i could potentially hide or hang things from for some angle shots.. not sure as may get in shot.. will have to test but thought worth mentioning.
*Both cabinetry in background behind and to the side of the subject and on sides has space atop for lights (6+ above the subject's head)
*There will be windows from behind and on the sides of the camera. I can always close the honeycomb blinds though.
*Fridge, Oven located on side of wall and stove are all black in color
Potential problems:
*No white walls to bounce light off--could use a soft sheet set up?
*Want to stay away from tungsten lights
*Ceilings have with 75 watt sylvania flood lights with 120 volt and is controlled via dimmer switches--should i turn them off completely
*Background windows with daylight coming through--could have a light coming through from the outside?
*Only 5'6" feet of space behind subject--is this enough space for backlight to show depth/space behind subject--how can i increase the depth
Goal:
*Purchase a 3 point lighting kit (I want to purchase separate pieces if possible.. no kits) containing all fluorescent lights that will brighten up this space and give depth.
*Make inviting to watch.. without overcasts or blindspots in an environment with many textures and colors
*Tone down any kitchen gadgets used--silver mostly
*Show larger depth behind subject
*Have light come through windows
I know there is more to note however, Im getting dizzy with what i have already written.. and oh yea this video is far cooking instructional's. I will be doing a lot more with this video... but i'll save that for another day. If it will be of benefit i can always take a pic of the area...
Your lighting experience is appreciated and definitely needed!!! Robyne
*35' ceilings
Potential problems:
Goal:
