Duke M.
I received my Berkey top plate and a few things were different than I expected.
1) They said it was reversible. I imagined you flipped the plate over. You don't. There are rubber pads underneath. Instead it's a small h shape and you rotate the plate to have either two 'fingers' in the front, or one.
2) It has a measuring tape attachment stud. At first I thought it was on the wrong end for what I wanted, but I found out that the stud is reversible to the other side too.
3) It came with a special allen type screwdriver for mounting the plate instead of a cheap little allen wrench. It has a nice little Berkey inlay too.
4) I assumed the missing finger (changing it from an H to an h) was simply to allow the plate to be inserted under the handle. However, when playing with it I found that it fits perfectly under the mic holder, which would have been a difficult area to mount anything anyway, so it makes sense to have it there.
All in all better thought out and designed than I expected. It immediately added rigidity and strength where I wanted to mount accessories. Well done.
