What do you intend to use your gears with? For example: some kind of follow-focus accessory or remote control, etc.? Have your machinist friends actually measure the pitch of the mating gear(s) and make your gears to match. If they are good machinists, they should be able to do this. If not, you are doing them a favor and prompting them to learn something important to their trade.
I agree with twotonepunkkid that the Zacuto plastic gear strips are probably much more practical (and interchangably usable) than machining hard gears for a particular diameter. The Zacuto plastic strips can be attached to the lens using the kind of double-stick tape used for vehicle body work (for chrome accessories and decoration, etc.) There is a good reference in this forum demonstrating this technique.
