G Gene Sung Veteran May 14, 2014 #1 I was wondering if the Metadata from the 7Q is necessary for anything? I've been using Josh Becker's search > .mov method of copying over 4K2HD files so that way they end up in the same folder and not all the separate folders. Do I need to copy the Metadata as well? Thanks
C Colinelves Well-known member May 14, 2014 #2 I suspect the metadata helps the CD clips transfer programme to stitch the clips together properly.
