72mm Tiffen Circular Polarizer Filter -- Rotating front?? Can't use matte box? :(
justmarvin
I just ordered a 72mm Circular polarizer filter from dvestore here: http://dvcreators.net/tiffen-filters
The filter is made of two rings attached together. The bottom ring screws on tight to the dvx100b, and the top part is the rotating ring - it does not have a "lock" so it will keep rotating if you keep turning it.
The problem is, I can't screw my matte box on top of the polarizer because the polarizer will "turn" to the right or left when my matte box is on it, because only the bottom part of the polarizer screws on tightly but the top is still able to turn...
Anyone have a solution around that? Like how to make the polarizer top ring lock.
Do all polarizer screw-in filters have a top rotating ring?
