720pN 24fps @ 60 fps?!
High1ander
I know the HVX got 24fps and 30 fps preset at 720 pN, but what happens when I chose 24 fps pN and up the FPS to 60. Is it still pN or should i just use the 720p @ 60 fps preset?
Really does changing framerate on 24 fps and 30 fps negates the pN mode?
720/24pN at 60fps and 720/60p are both taking 60 progressive frames per second (1GB per minute). But if you should 720/24pN/60fps, there will be no audio, and it will be a slow motion 24p clip. If you shoot 720/60p, it Does record audio, and it will be a normal speed 60fps clip (which you can convert to a 24p or 30p slow mo clip in post).
