720p PAL variable frame rates workaround in FCP
SPZ
This is an expensive workaround, but it should work. I've been using my HVX PAL, and discovered something that can be the path for us to use the slow motion and fast motion effects of 720p in FCP.
The camera comes with a component out cable. There's an option that lets you select to output the signal to 1080i. This works to output the 720p material too. I know this because I shot some slow motion stuff and saw it on my 1080i only crt. It looked great.
So I assume if one has a capture card that has component in, and captures with the dvcprohd codec, one can have the variable frame rates effect in a 1080i 50 timeline. Now the question is:
Who has a Kona card, or a cheap capture card for mac in order to try this out?
And more: What is our cheapest option?
And one more thing I saw. In my powerbook, seeing an edited dvcprohd in quicktime 7.00 was CRAP- full of noise. Updated it to Quicktime 7.04, and it looks like what you see in FCP: clean.
One last thing: I updated my laptop with updates for my old mac production studio (BIG MISTAKE) and while before it could play back dvcprohd smoothly, now it struggles. Damn.
And I still can't export a widescreen dvcprohd file compressed in H264. The irony is I used flip4mac and it exported widescreen to WMV! Strange, indeed.
Has anyone discovered a way to convert the .mxf files with another application into a usable quicktime/avi file? PC based or Mac? Ultimately need to export an image sequence for post production animation use. This workaround above is beyond my means!
Please help if you can. anyone out there?
Many thanks
Martin
Sounds a very interesting workaround.
I've got the Kona Lhe for the Quad but I just got it so I havn't it installed yet. But most importantly I still havn't got the HVX200. I'm waiting to be sure of my workflow firstly and that includes firestore/cineporter storage solutions. But if the workaround you suggests works that would be one problem solved for the time being and I'd be one step closer to getting the HVX :)
