Paul Nordin
great replies guys, thanks.
720p is definitely what I'll be shooting in to take advantage of all the HVX coolness.
So what you're saying is that if I'm careful with my shooting and do a decent colour grade all should be fine? yay!
Hi Sam,
I've shot 7 features and countless other projects using an HVX in a variety of configurations and formats. 1-SD (DVCPro50), 3-720PN24, 3-1080P24. Basicallly, you can make any of these look good on a film-out, with varying degrees of crispness. You haven't mentioned why you are wanting to shoot 720 vs 1080. Is it for a specific grain/noise pattern that 720 provides, or are you planning crazy-long takes for which the added run-time of the 720PN is better suited? I disagree with posters that say you cannot tell a difference. You can. That plus the 20% or so of added resolution of 1080 over 720 gives the post production team a bit more resolution to work with as they tweak the edit. For my two cents, I would not shoot another foot of 720 for a feature project unless there was a motivating reason (style of speed). It used to be that 720 helped with the workflow since you could get 10min on a 4g card, and it requires so fewer GB of Hard Disk space for the project backups. However, in the 2 years the HVX has been in service, HD cost per GB has come down 60-80% so that's not really a meaningful savings anymore.
That said, on features I will still drop the HVX down to 720PN for off-speed shots (over/under-cranked), and uprez that result into a 1080 timeline in post with the rest of the footage...it still comes out looking great.
Cheers,
Paul
