720p 25pn pal!! help
kabira786
I shot some footage in 720p 25pn I couldnt see any editing softare which takes this format.
Can any one please help! I really want to shoot in this format and Iam getting very concerned.
any platform really, as long as it does the job. will it work on premiere pro thoff?
and are you sure it will do 720p 25pn on edius?
Use Raylight - It will convert it to an avi and then premiere can take it. In premiere you need to set a costom size on startup - 720p 25fps
the easy way is using edius or final cut pro.
if not, you must use an intermediate software such as the raylight.
I did a whle shoot in this format and i can edit it quite nicely in Final Cut Pro. I had to tweak the preset a little to get it to work, but it works well.
I shoot 720/25pn exclusively and Edius edits it like it was DV. Fast and bulletproof.
Edius needs getting used to, but so do all the others.
kabir said:
Will I lose quality if I convert it to avi?
Thanx a lot you guyz for ur help.
If you're using Vegas+raylight or Premiere+raylight you can take the 25P MXF file straight into the editor. For After Effects and other apps the Raylight AVI's are either linked to original MXF file or its a direct copy of it, so no loss in quality as long as you're in Raylight Blue for the final render. The Raylight Tutorial has more info at
http://dvfilm.com/raylight/raylightTutorial2Index.htm
fcp 25pn support
fcp 25pn support
Does FCP support 720p 25PN now?? Can't see it anywhere under easy setup (fcp 5.1.4) Am I missung something?
