I have to conform 5DM2 30p to 25p. I do it using Cinema Tools and then Twixtor in After Effects, to change cinema tools output's speed. The result is really good in motion, much better than any other process ("Bloom method" is too strobe like).
BUT there is a serious problem. I apply Twixtor to the final editing, the full movie exported from Final Cut Pro. Twixtor blends frames so, when there is a cut, it blends the last frame of the first shot and the first frame of the second shot. It's very bad to see it, bacause it contains warping. It's fast, very fast (just one frame) but it's bad. It doesn't happen in every cut, but just sometimes: maybe it happens when the visual content of the two shots is similar; it doesn't happen when the visual content is very different.
It's present with any settings both in "motion vector" and "frame interpolation".
Is there some way to avoid it ? Hope so. Twixtor is very good, indeed.
Thanks,
Egon
Thanks,
Egon
