If you use a clean preamp to allow recording in camera with a mic level of +1 above 0 while hitting -12dB, you'll get a very low noise floor: effectively no hiss. I've done this with the Sennheiser G3 receiver and with the Sound Devices USBPre2 (standalone mode): excellent results. Example with somewhat noisy dynamic mics: http://www.youtube.com/watch?v=2bWGogt2Kxg
jcs, your video is set to 'private'
Did you consider a juicedlink solution over the SoundDevices? What 'noisy' mics did you use?
Listening to the 60 MB Vimeo download version, the audio sounds muffled, like the upper range is missing. I have no idea if this is the mics or the Canon recording.
Also in the background there is a definite "fan" or AC unit hum that is not helping at all.
...As a side note, the 5D MK3 image looks great. Very nice indeed.
99.99% of listener's can't hear the hum- no reason to spend time removing it.
Jon Fairhurst posted demos on Cinema5D a few years ago showing that the Mark II with a good preamp sounded better than any of the sub $500 (and perhaps sub $1000) external recorders
See this chart to see the noise levels of many common external recorders: http://www.avisoft.com/recordertests.htm
The USBPre2 has the same hardware topology as the 722 (top of the chart)
I also have the DR100mkII- its AD converters are very noisy compared to the SD ADs.
In terms of noise performance and cost, the Fostex FR-2LE is the best deal.
