5D mkii to Red Camera
Depends on length of project and amount of effects, I did a 7 minute video recently with some heavy effects and it took me 2hrs to render from Davinci and 3hrs out of AE, grand total of 5hrs for a 7 minute video. May seem like a lot, but considering I only had to render my timeline in Premiere once and it took all of 40 mins, compared to have to transcode footage on ingest, render my timeline, and then go through post with similar render times with my old workflow. Now that I have worked it out this workflow is much better than my previous one with DSLR's and camcorders.
But it all comes down to you and your work style, much less about this camera fits all, or on the other hand this camera can never shot so and so, as it's up to the situation clients and your skills.
I'd save money on the red rocket and just buy a proper computer, because with one render times are no problem, especially if you know how to efficiently work with your material in post to avoid things that cause render times to jump unnecessarily. For instance my render times would jump drastically in AE for no reason but when I restart my comp they drop back down, most likely an issue I could sort without the restart but.. mah. I also found stacking effects causes a massive jump where if you do multiple passes the times are drastically less. I wonder how many who complain of reds post have worked with it themselves and recently? (on a decent computer)
If you are working with over 50-60 files ( about 3-5mins each) and you need to color grade and transcode them, tell me a faster way.... Average about 30-40mins per clip and you can see the pain it can be. Also RED will have more noise than a C300 as it is not as low light sensitive.
I'm just talking in reference to the OP who shoots music videos. the only footage you need to render and transcode is the final timeline which should be less than ten minutes... if you are working in adobe not sure about FCX which I do not use and proxies is not my kind of workflow.
the noise level is rather subjective seeing as red does no in camera noise reduction like the canon's and if you run red footage through neat video it's amazing the footage you can get. Considering render times again I'm not even using neat video on the r3d's but from my DNxHD files out of davinci and it still works wonders. but like I said it's up to you and how you work so blanket statements about any camera or workflow are a little unusual to me.
When clients want to see the footage recorded and don't understand red raw and why it looks like that what are you supposed to do? This is speaking on working on Music Videos for Record labels and all of the above and different people it needs to go through. Also many times you need to render out good high quality levels so you can see exactly how it's going to look and if it even works. No way you put it, Red work flow and Canon c300 is not the same.
I'm sorry we appear to be having two different conversations, why is the C300 being brought up? if that is your workflow/camera great I'm not knocking it just saying not everyone works the same. since the red one there have been hundreds(might be an exaggeration but Dino g has shot a lot) of music videos on red one and now epic/scarlet, plenty of people shoot with reds it's a choice, don't like them or the workflow then don't that is another choice, like the c300 great make that choice. but the speed of post with red is not as bad as it's made out, you want dailies/proxies use an external recorder(they are real cheap) or create custom in camera looks for each setup, have a backup camera and use it for playback(horrible idea but I'm just thinking here) mah either way plenty of workarounds for every scenario all depends on what your end game is, and your preferences are, and who you are delivering your project too.
take er easy and have a good one!
Maybe you have not paid attention to this thread. The op shoots on 5d and is considering RED, myself and others said RED might be overkill for what he is doing. An alternative could be Mark III or C300 which is basically the same workflow.
You on the other hand think that RED is as fast or faster than working with 5d footage in Post as you stated, which is what I do not agree with.... Simple.
So instead of the OP learning a new work flow which will require time and be more expensive on all fronts he can step up his quality and go with a C300 or even C500 which will be the same workflow but the overall image will be better. That imo would be better than jumping to RED.
Maybe even the new Canon 1D C shooting 4k can be a good option as well. At the end though I've worked with RED and imo I will steer a client away as honestly for youtube viewing it's not such a big difference, especially when it's being down sized to 720-1080p.[h=1][/h]
yes but I never mentioned the C300(well I did in relation to your noise comment but admittedly I was confused as to it's inclusion there as well), I was addressing saying red footage was slow in general, I never mentioned the 5D. just said it was faster than my old workflow, once again you are building a battle where there is none.
I'm just posing another view no need for him to take it on just pointing out what I have experienced as you are. This is about helping the OP not arguning over personal views of which camera we each think would suit him better. considering we don't know his workflow or clients all we can do is give him advice based on our experince which we have... I see no issue with that.
perhaps if we were talking about alexa C300 and the 5D this conversation would have gone differently....
sorry didn't mean to offend just adding the opposite side of the coin.
No offend , just different point of views which makes these forums great. I'm not saying you are right or wrong just different opinions , that's all. Personally I love the image you can get out of RED, but also feel at least on what I have experienced that there is more to the workflow and overall cost than just stepping up with the Canon Cinema line. Also for these videos where they are obviously a lot less than $10k I also feel RED is overkill.
Now if we are shooting million dollar movies and need 5k res than Red is second to none, but at last my opinion still stands that for shooting and delivering 720-1080p footage the C300 or even c100 cinema camera might be an option to look too. Regardless apologies if you felt I came off negativity as that is not my position
peace
Fair enough, no problem at all, I find anything can be used for anything there is no overkill when it comes to art or craft but in business there most definitely is. If money is an issue then yes don't blow your budget on a red. If you can't justify the expense over the increased quality do not get it, and that goes with any camera, though red has more hidden costs than most, all cameras have hidden costs be it time or money so there is that to consider as well.
Have good one!
I've owned a GH1 and 5d ii and now a Scarlet. When ever using the camera or looking at the images it creates I've never once looked back. That being said rendering can be a ***** (on my 4 year old macbook pro), but the quality is well worth my time for the work I do.
Some people need to deliver transcoded clips to their clients for them to be happy until the final product is done. Others can work with the original files and produce an output-codec file only at the end of their workflow. Different needs, different tools.
And I fall into the former. Always uploading H.264 transcodes with timecode to Vimeo or Dropbox for clients to review. I cannot fathom dropping Red Raw footage into my workflow without the benefit of a Red Rocket card (which, contrary to what has been said here, shows no evidence of being EOL'd).
I'll say this much - the artists in Toronto know what RED is and they want it. Definitely not "overkill" in the lower budgeted videos. As they get higher in budget range, the camera matters little. We shot a $30K video with a 5DMK3 and a $3.5K video on RED.
Kegan
That's great and all, but can the OP afford it? Obviously, if Scarlet/Epic is something that you could afford, and you can shoot $30k+ video in addition to $3.5k videos, then it's, frankly, a no-brainer. But if you're rarely hitting even the $3.5k budget for a video, and you can barely afford the base price for the Scarlet body, then Red is not for you.
Kegan
A dp I work with charges $2500 for a c300 and set of Zeiss lenses. That same dp charges $3000 for the Red and more because he needs an assistant. With a 10k budget I opted to shoot on the c300 and that $1000 I saved I put it into the project. The artist wanted RED even almost to a point that he demanded it, but I convinced him out of it and at the end he was more than happy with the c300.
He said he already has the coin to make the purchase. I know what he's going through, rap is monkey see monkey do. If cats see a RED in their favorite artist behind the scenes vid...they want to see it on their set. If he's getting a good volume of work with available production value (read someone's house and a friends car) he can get over and make a killing with a RED off of volume alone. Neither of the OP's videos looked to require massive crew and make up or craft services to get completed. These guys come as they are where they are, and if you can get $3500 for a day of shooting and slapping MBL on some footage...sweet.
I have a MK2, MK3 and Scarlet. First I really don't get the comment about how the footage looks when showing a client. The Scarlet records raw data, so you can tune the look of your monitor output to suit the tastes of the project, or the client. In the end, it will not change the image data actually recorded, as it is raw. With ISO, color temp, and most other settings, you're only changing the metadata, not the image. I will say that working with raw footage is more than worth the minor inconveniences. I used to cut on FCP but switched to a blazin fast pc and CS6 and have never looked back. Haven't had a need for a RR yet. I love the fact that when a higher end project rolls in I have it covered.
Tell me about this blazing fast PC? I need information to buy one.
ASUS P6X58-E Pro 220$
Intel i7-980 Hex Core 580$
G.SKILL Ripjaws 24GB (6 x 4GB) SDRAM DDR3 1600 (PC3 12800) 150$
WD VelociRaptor WD6000HLHX 600GB 10,000RPM 250$
Quadro4000 700$
Antec Nine Hundred Two v3Black ATX 119$
CORSAIR CMPSU-850TX 850W 135$
Win 7 Prof OEM 139$
BDR-206 99$
This is my System,no need Red rocket card.I am working Scarlet r3d file with Adobe cs6 no problem at all.
This is new Videoguys recomondation
Motherboard ASUS P9X79 Pro Model $329.00
Processor Intel Core i7 3930K Sandy Bridge-E 3.2GHz $599.00
RAM 32GB G.Skill Ripjaws Z 8x4 GB kit $129.00
Boot Drive Crucial M4 256GB SSD $199.00
Case Antec Three Hundred Illusion Black Steel ATX Mid Tower $60.00
Power Supply CORSAIR CMPSU-850TX 850W $140.00
CPU Cooler COOLER MASTER Hyper 212 EVO $35.00
Blu-ray Burner Pioneer BDR-208 Blu-Ray Disc Burner $90.00
OS Windows 7 Professional 64-bit $129.00
GPU EVGA 02G-P4-2678-KR GeForce GTX 670 $399.00
http://www.videoguys.com/Guide/E/Vi...dge+E/0xe9b142f408a2b03ab88144a434e88de7.aspx
Quadro4000 700$
Win 7 Prof OEM 139$
BDR-206 99$
Does someone sell one already built?
