521EX Remote: First Impressions
basspig
B&H Shipped Monday and I took delivery of a Manfrotto 521EX remote zoom controller earlier today.
My first impression was "very light". And when I took it out of the box, I thought the cable was missing. But actually, it ships, wrapped around the controller.
It seems lightweight and plasticy and very small. Okay, enough for impressions.
Functionality: Clipped it onto the pan bar of an Impact VT2500 tripod. Clamp assembly seems a bit weak, but adequate.
The speed control dial is very thin and this controller can not be left on the pan bar when shipping the tripod, or one bump and this protruding dial will break.
Easy hookup, with the 8-pin plug mating to the EX1's socket on the hand grip.
Powered on the EX1 and the remote immediately worked.
The zoom rocker could be smoother, in my opinion. The first 1/3 of the travel does nothing, then a smidge further and the zoom lens "jumps" to action at a fairly fast speed.
Using the rotary speed control at the lowest setting, I found I was able to get more satisfactory 'creep zoom' startups, but it is still tricky and takes some practice.
The two fast zoom in/out buttons have their usefulness in these slow dial modes. The top button previews the last clip recorded. The big, red REC button does, well, you know.
Now the buttons are a bit close together. I would be concerned about hitting the REC button when I was meaning to hit one of the snap zoom buttons. We'll see how this works out. I have an Oct 18 symphony concert coming up and I'll have to go over this with my camera operators well in advance.
Bottom line: It seems a bit chintzy compared to my 532-PRO that I use with the V1U, but it does do the job. The $249 price tag seems high, once you get the unit in-hand and see how insubstantial it is in terms of construction. Will I buy another? Sure. I need matching controllers for all of my EX1s and this is "good enough" at this price.
Mark,
I don't believe any external controller can easily provide creeping zooms, since the lens itself cannot do them. I've read something about too much hysteresis in the motor preventing smooth starts and stops. With a lot of practice one can get lucky, but seldom in real time when you actually need the thing to work.
In any case, you may find the Bebob Zoe EX1 controller to be of higher build quality. I have one, and like it a lot. I just wish the lens were of a more refined design. The Zoe seems to work best with the speed dial in the middle. It has a very solid mounting bracket for the tripod arm.
Getting good slow zooms is enough of an issue for me that I will eventually get an EX3 and a real lens. Maybe the Fuji 17X that B&H sells for $7600 can zoom smoothly. I can only hope. If not, there's always the one that costs $23K. Sheesh.
Dave McCallister
